How To Obtain The Composition Of The Flare Gas
#1 ogpprocessing
ogpprocessing
  • 142 posts
Posted 27 May 2010 - 12:48 PM
Dear,
During preparation of the flare stack process data sheet, the detailed composition of the relieving streams for governing and important scenarios are requested by flare stack Vendor.
Softwares like Flarenet only provide us with MW values and not the detailed composition of the entering streams to the flare stack.
So which method do you recommend for this?
Edited by ogpprocessing, 30 May 2010 - 06:43 AM.
#2 rxnarang
rxnarang
  • 133 posts
Posted 29 May 2010 - 10:17 PM
Flarenet does provide the composition. The options have to be chekced on for this, as the defaults do not offer this.
#3 ogpprocessing
ogpprocessing
  • 142 posts
Posted 30 May 2010 - 12:48 AM
Dear,
What you have mentioned is only possible for provision of the source data including PSV or Control Valve.
But for streams within the network (for example entering the main flare header and outgoing from the main header)Flarenet only provides MW values.
So my problem is that I should provide the detailed composition of the streams entering the stack.
If you know any method for doing this could you please guide me how should I change the Flarenet settings to have the composition of the relieving streams after a run?
Edited by ogpprocessing, 30 May 2010 - 06:48 AM.
