I want to simulate a liquid-liquid extraction column using Aspen Plus software. In this column the aromatic components available in a petroleum vacuum column product stream extracted by Furfural as extract stream.
I have the True Boiling Point (TBP) and gravity specifications for feed, raffinate and extract streams and I specified these components for Aspen as three assays but I couldn’t complete the Setup form of EXTRACT column because in the Setup Key Components Sheet there aren’t IDs of any assay type components.
Do you know how I can simulate this process? Would you please help me?!
Thanks in advance.
Sincerely,
Hossein
Liq-Liq Extraction In Aspen+
Started by hkarimi, May 31 2010 09:47 AM
No replies to this topic
Posted 31 May 2010 - 09:47 AM
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Prv Vs Extraction Condensing TurbineStarted by Guest_mj311_* , 13 Nov 2024 |
