Here is brief description of my question:
When sizing fired reboilers, we come across sizing of fire tube. We normally size fire tube based on the maximum heat flux. We find the surface area of fire tube based on the reboiler duty and heat flux:
Heat Transfer Surface Area = Process Heat Duty/Max. Allowable Heat Flux
After calculating the surface area, we select the fire tube dia and length that satisfies the calculated surface area. Only thing which limits the fire tube dia is heat density. We have to keep heat density below the maximum value to avoid instability of flame.
I am concerned about heating value of fuel because in all above calculations, heating value has not been used. If heating value is large, flow of fuel gas and flue gases will be small. Result is low velocity and low heat transfer rate. If heating value is small, flow of fuel gas and flue gases will be large which will increase the velocity and heat transfer rate.
I want to know the effect of change in heating value of fuel gas on performance of the reboiler. Please advise any other method which takes into account the heating value of gas.
