I am required to review FEED documents for an LNG Terminal. Specifically I am interested to know if anyone has had any experience of conducting such reviews (especially Safety documentation), and if yes, what types of templates, etc. were used.
Feed Review
Started by , Jun 29 2010 11:51 AM
Posted 29 June 2010 - 11:51 AM
Posted 30 June 2010 - 12:55 PM
It all depends on what is expected from your review, and up to what level of details: perhaps you need only to verify that the process inputs used in FEED are consistent and accurate, or perhaps to verify some of the critical design parameters (as an example, we have been engaged in the current project for evaluating design solutions for some areas judged as critical: offshore flare system, Mol Sieve KO drum and dehydration capacity, heat removal capacity in refrigerant systems, Pipeline overpressure protection system etc). What outputs/feedback is expected from your review?
Dynamic Simulation After Feed Flow ReductionStarted by Guest_Kakashi-01_* , 20 Mar 2025 |
Split The Feed Into Two Identical StreamsStarted by Guest_tomr91_* , 16 Mar 2025 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
Molten Sulfer Feed ControlStarted by Guest_mahmooddalvi09_* , 11 Jan 2024 |
