I am trying to simulate a heat exchanger which is shown as 18E002 on the attached figure. the tube side is process gas (N2, H2, CO2 Water, CH4, C2H4, C2H6, C3H6 and C3H8) shell side is a refrigerant (Ammonia, water). As you can see in the PFD, there are two streams leaving the shell (a vapor and a bleed stream of ammonia). I would like to know how I can simulate this heat exchanger in which different streams with different properties are leaving the shell in HTRI . the Heat exchanger in TEMA BKU type by the way.other info are as follows:
1- Tube length: 6000 mm
2- Number of tubes: 3256
3- Tube O.D and wall thickness: 19.05 * 2.11 mm
4- Area: 1250 m2
5- Tube layout/ pitch: 90 / 28.575mm
6- 2 passes on tube side
Thnaks in advance
