I have a problem in deciding among three options available for one blow down drum size in our plant. Our client wants us to study the three availeble possibilities for blow down drum size (leading to different flare loads). Attached you can see the three cases. I have also attached the diagrams regarding each case.
Which case do you think is the best option? (assume that there is no space limitation). it should also be noted that we have another unit adjacent to our plant sharing a common flare.
Thanks in advance
