Hello everybody..!.
In this opportunity i would like to ask about if someone can help me with a spreadsheet that calculates the maximun required data for a Tank foam system.
In this case i`m talking about Foam Dam Height, number of risers, Foam Chamber Spacing, min. number of Chamber Required, header size, minimum pressure at base of Riser, foam application rate...and anything that relates to this topic.
In advance thanks a lot..!.
Best;
Foam System Calculation
Started by Mech.Engineer, Aug 19 2010 02:28 PM
No replies to this topic
Posted 19 August 2010 - 02:28 PM
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
