Recently, I just try to develop NGL recovery using turbo-expander like in the PFD I attach below. All data required are inserted for each stream. When I want to run demethanizer column (the 1st column), the error status is appeared, "column 23 does not have enough information for the column to run". I just insert pressure and temperature in stream 23. is anything I missed?
Besides that, is it possible to run two fractional column simultaneously like in the PFD I attach below? All your help are highly appreciated. Thank you
