Dear all,
I have been posed by many young entry level engineers about gas density calculations which I do in a jiffy using a calculator. I will try to summarize these below:
As a basic we are all supposed to know that gas density is calculated as:
rho = P*M / R*T*Z ------------- 1
or
rho = M / ((R*T*Z) / P) ----------- 2
where:
rho = gas density
M = Molecular weight of gas
R = Universal gas constant
T = Absolute Temperature
P = Absolute Pressure
For different standard conditions the denominator in equation 2, i.e. (R*T*Z/P) varies and below are a few examples:
Standard Conditions 1:
P = 1.01325 bar (abs), T = 15.6 deg C = 288.75 K, Z =1
R = 0.0831447 bara.m3/kmole.K
rho = M / 23.7 kg/m3
Standard Conditions 2:
P = 1.01325 bar (abs), T = 0 deg C = 273.15 K, Z =1
rho = M / 22.414 kg/m3
Note: These are also called normal conditions and the volume defined as Nm3. The term normal is archaic in today's definition of standard conditions of temperature and pressure.
Standard Conditions 3:
P = 1.01325 bar (abs), T = 15 deg C = 288.15 K, Z =1
rho = M / 23.64 kg/m3
Standard Conditions 4:
P = 14.696 psia, T = 60 deg F = 519.67 R, Z =1
R = 10.7316 psia.ft3/lbmole.R
rho = M / 379.5 lb/ft3
Note: The compressibility factor Z is practically unity at all standard conditions mentioned above.
The utility of the standard density is to convert standard volume flow in Sm3 or Scf to mass flow by multiplying it with the standard density, given the standard conditions. It is always good engineering practice to specify the standard conditions in the "Design Basis" document of the particular project being executed. For more details on standard conditions of temperature and pressure please refer the following link:
http://en.wikipedia....re_and_pressure
Short Cut Formulas For Gas Densities At Various Std.conditions
Started by ankur2061, Aug 24 2010 03:38 AM
No replies to this topic
Posted 24 August 2010 - 03:38 AM
Lng Regasification: Heat Exchanger Operating ConditionsStarted by Guest_wangdee.s_* , 17 Nov 2024 |
![]() Fan Laws For Centrifugal Compressors And Varying Suction ConditionsStarted by Guest_SickPuppy0_* , 25 Jan 2023 |
![]() Standard ConditionsStarted by Guest_panoska_* , 06 Mar 2022 |
Blowdown Valve Initial ConditionsStarted by Guest_powerox6_* , 22 Jul 2023 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Recent blog entries on this topic
Short Cut Formulas For Gas Densities At Various Standard Conditions
By ankur2061 in Ankur's_Chemical_Engg_Blog, on 10 February 2012 - 03:42 AM
Dear all,
I have been posed by many young entry level engineers about standard gas density calculations which I do in a jiffy using a calculator. I will try to summarize these below:
or
where:
rho = gas...
or
where:
rho = gas...
Read Full Entry →
