Vertical Thermosyphon Reboilers
  • guestGuests
  • 0 posts
Posted 07 September 2010 - 01:20 AM
Good day
I need help designing a vertical thermosyphon reboiler. I have done some research and have obtained guides that seem pretty helpful..however id like to know where I coud get a list of requirements to be considered. This should includhe ratio of things like the ratio od the design heat flux to the maximum allowable heat flux, as well as initial guess vaues for tube inlet velocities and diameters and so on. Where do I even start when making these assumptions?
Thanking you in advance
Lady-engineer:)
#2 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 07 September 2010 - 08:39 AM
Dear,
There are lots of discussions available for theromsyphon reboilers system design here, just search and you will find those. Here is the link,
http://www.cheresour...h&fromMainBar=1
I am uploading the notes of lecture where most of the reboiling system design considerations are covered in brief.
