In attach please find foaming tendency of amine gas treating solution procedure. I appreciate to everybody to review this procedure if it is right on or not.
Posted 18 September 2010 - 06:58 AM
Posted 18 September 2010 - 07:41 AM
Posted 19 September 2010 - 04:14 AM
The procedure seems to be quite in place although different vendors (e.g. BASF, Huntsman, SNEA/Total etc.) may have different guidelines/test methods for determining Foaming parameters.
The simplest one I have seen was to mix equal quantities of amine and demineralized water, shake the sample by hands (without specifying shaking frequency and amplitude) and then measure the foam volume and the foam breaking time. Surprisingly, but it doesn't appear that bad as it may sound.
Another (similar) type of testing is attached below.
Posted 19 September 2010 - 05:10 AM
Posted 23 September 2010 - 10:08 PM
Posted 01 February 2012 - 10:50 PM
Posted 07 February 2012 - 10:47 PM
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
![]() Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Foaming Issue In MegStarted by Guest_akashlovey_* , 11 Aug 2024 |
