I am a ChE masters student currently evaluating the removal of residual dyes via simultaneous multicomponent adsorption with AC.
My concern is related with respect to the calculation of the ADMI value.
Info:
- Using APHA method, published in Standard Methods for the examination of waste water.
- Not using CIElab method
- All tristimulus values for the blank, sample and pH corrected sample have been determined.
- Tristimuli have been converted to Munsell values using tables in Wysecki and Stiles' Color Science.
- Adams-Nickerson color difference (DE) has been calculated.
Problem:
- Calculation of ADMI????
No stock color samples have been prepared. Is this really necessary?
http://www.cheresour...do=new_post&f=2
The above article, refers to the calculation of a calibration factor (F), and then from there determine the ADMI value. However I don't have a clue what this APHA value is. Some texts sais the APHA value is the ADMI value??? CONFUSED....
There is also a way of determining the ADMI value by method of least squares. where ADMI = DE/a+(b*DE). If i'm not mistaken, you require ADMI values to do this (dependent variable), but that is what I want to determine.
SO LOST!!!
Please, if someone knows more about this subject matter, I NEED YOUR HELP!
I would like to get the chemistry (analytical) out of the way in order to focus on the engineering aspects.
Determination Of Admi
Started by Flux, Oct 17 2010 06:32 PM
No replies to this topic
Posted 17 October 2010 - 06:32 PM
Screw Compressor Suction Pressure DeterminationStarted by Guest_Deicide Dunkelheit_* , 22 Jan 2025 |
![]() Determination Of The Number Of Foam Chambers For Storage TanksStarted by Guest_AnbIran_* , 15 Feb 2024 |
Order Of Reaction DeterminationStarted by Guest_shamsoddin 1989_* , 09 Feb 2023 |
Determination Of Theoretical Oxygen DemandStarted by Guest_meer_* , 09 Feb 2020 |
![]() Surface Area DeterminationStarted by Guest_etukjoshua_* , 05 Aug 2017 |
