Senior people in my workplace comment that it is a mandatory to install a centrifugal vertical pump prior to reciprocating plunger pump, to provide adequate NPSHA and to maintain liquid level at De-Oxy Tower at stable level, due to pulsation results if I install plunger pump only at downstream of the tower.
However, I've calculated that NPSHA is enough already without installing this centrifugal pump prior to reciprocating pump. The remaining problem is liquid level disturbance due to pulsation of reciprocating pump. However, I think this problem can be solved by installing a pulsation dampener at De-Oxy tower downstream prior to reciprocating pump.
Am I right? Or wrong? Needs advice from this forum expert due to my junior experience in this matter.
Edited by manchester, 21 October 2010 - 07:13 PM.
