Can someone please tell me the thermal conductivity of LHV 1:2:4 insulating castable!
Thanks,
Saoud.
Thermal Conductivty
Started by Guest_Saoud_*, Apr 29 2005 08:13 AM
Guest_Saoud_*
Posted 29 April 2005 - 08:13 AM
Posted 29 April 2005 - 08:46 AM
Perhaps if you identify what your acronym "LHV" means, we can be of some help to you. It is not logical to expect engineers to memorize every conceivable acronym that exists or is made up - and know its meaning. We have much better things to do besides that. Is this a castable refractory? If so, then simply state it. Any additional data or information about what you propose to use it for may help get you what you need.
If you use an acronym, please apply the conventional and expected practice of at least identifying it within parentheses the first time you use it in a written script.
Guest_Saoud_*
Posted 29 April 2005 - 09:01 AM
Im sorry for not identifying what LHV means. LHV stands for Lumnite-Haydite-Vermiculite, and it has 1:2:4 mix by volume. Yes, it is a castable refractory.
Posted 29 April 2005 - 10:25 AM
Saoud:
In less than 5 minutes I was able to access the Google database and when I keyed in Vermiculite- refractory I found:
http://www.ablerefra...0insulcast.html
where the following can be downloaded:
Able 1-2-4 - Data Sheet pdf
Blend of lumnite cement with haydite and vermiculite aggregates. It provides an excellent insulation as back-up material or as a hot face lining when temperatures do not exceed 2,000 F.
The Adobe document has, on the first page, the thermal conductivities (at different temperatures) you state you are looking for.
Now, level with me: am I the most brilliant and intelligent engineer in the Cosmos or are you just a lazy and non-inquisitive engineering student that requires his milk bottle be inserted into his mouth when he is hungry? I ask these questions to make a point to other students who might also read this.
Guest_Saoud_*
Posted 30 April 2005 - 10:31 AM
Thank you very much.
I think you are genius in comparison with me...
The problem is i tried the google but unfortunately the search results were unsatisfactory, this is why i was asking for help and thanks to you i got what i was looking for.
Good luck,
Saoud.
Good luck,
Saoud.
Thermal Oxidizer HeaderStarted by Guest_ryn376_* , 29 Jan 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Thermal FuseStarted by Guest_Dr_bigfoot_* , 09 Apr 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
