I'am looking for a unit or system to control the temperature of the condensor. The streams that are available are the following:
- cooling water at ambient temperature
- chilled water at 5-7°C
- Steam at 3-4 bar
Is it possible to use these streams (one or more) to create a system to use water of 85°C at one moment and perhaps some hours later water of 40°C and followed by perhaps 60°C, 20°C....
The water will be used to control the condensor temperature during reaction times with the possibility to set a setpunt of the water used for heat exchange with the product side in a shell and tube heat exchanger.
Condenser Temperature Control Unit
Started by echnat0n, Dec 29 2010 05:04 PM
Posted 29 December 2010 - 05:04 PM
Posted 30 December 2010 - 02:58 PM
echnat0n:
I do not understand clearly what you are proposing to do. You do not give us basic data:
- A detailed sketch of the system;
- The vapor composition being condensed;
- The type and configuration of the condenser being used;
- The detailed reason why you want to employ different fluids to “create” a cooling system. You should explain what are your goals and how you justify mixing/creating cooling water of different temperatures.
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Condenser DesignStarted by Guest_Kentucky08_* , 07 Dec 2025 |
Equal Load Sharing And Anti-Surge ControlStarted by Guest_panoska_* , 02 Nov 2025 |
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
