I am currently evaluating some existing spherical (spheroid) separators for three phase separation (oil/gas/water) efficiency. I have done many similar calculations before for horizontal and vertical vessels but never for a spherical vessel. Does anyone have a calculator/spreadsheet that can be used for separators of spherical or spheroid shape or else know what equation can be used for spherical separators for both 2 phase and 3 phase separation (ie gas from liquid and water from oil).
Basically these are existing separators that take the crude from the GOSPs and the crude contains both gas and produced water that are separated in the spheroids. I need to calculate whether the spheroids are large enough to meet the required water cut specification in the crude.
Spherical Separators
Started by AH1979, Feb 12 2011 04:29 AM
Posted 12 February 2011 - 04:29 AM
Posted 12 February 2011 - 05:40 AM
AH1979,
API SPEC 12J gives sizing methodology for all types of separators (vertical cylindrical, horizontal cylindrical and spherical). Appendix C gives design equations and calculations for all 3 types. The basic design equation based on modified Stoke's equation is the same for all 3 types. The difference lies in the K-factors depending on the geometry (vertical, horizontal and spherical) which are provided in Table C.1 of Appendix C in API SPEC 12J.
You may also refer GPSA Engineering Databook 11th Edition, Section 7 - Filters and Separators. Here also Fig 7-9 provides the C-factor and K-factor for spherical separators with the basic design equations for separators remaining the same.
Hope this helps.
Hope this helps.
Edited by ankur2061, 12 February 2011 - 05:47 AM.
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
Heat Absorbed By Spherical TankStarted by Guest_rasprocess2026_* , 11 Nov 2024 |
![]() Vertical Separators Best MethodStarted by Guest_fmalik_* , 02 Dec 2023 |
Nozzle Sizing In SeparatorsStarted by Guest_krishnamurthy_* , 30 May 2023 |
Spherical Butane Tank Blanket Gas Appropriate Standards To UseStarted by Guest_Sue N_* , 08 Jan 2021 |
