I was assigned to design (chemical design) the furnace for the combustion of H2S to SO2 according to chemical equation as below:
H2S + 3/2 O2 -----> SO2 + H2O
Inlet stream contains 96.5 mol% water, 1.8 mol% CO,1mol% CO2, 0.6 mol% H2S, 0.05 mol% H2 and 0.005 mol% COS. Combustion of H2S with oxygen in the air occurs in furnace at 1.5 bar and 540 deg Celsius. Molar flow rate of fuel stream is 9040 kmol/hr.
I would like know:
1. Should air be in excess in this combustion?
2. The total reaction rate of the equation above is not known. So to obtain the reaction rate, I'd written down the reaction mechanism (as per attached) which I found in the book of Combustion, 4th edition. (First 4 reactions are not given by the book..)The book suggested that at high temperature, three steps of reactions will occur. I wonder, is 500++deg Celsius high enough to be consider as high? I am aware that the furnace of Claus process operates at temperature above 1000 deg Celsius? Am I getting the correct reaction mechanism or did I miss any important reaction steps?
3. Will sulfur be produced at this temperature?
4. How does the real WSA furnace look like? Does WSA furnace burn up H2S completely in any existing plant?
5. To simplify the design process, can I assume that there is no presence of CO, CO2 and COS?
Any tips and tricks in this furnace design are welcome. Thank you in advance..
