I was recently given the calculation for emergency venting as per NFPA 30 using a "manhole with long bolts" as per the below.
CFH = 1,667*Cf*A*√(Pt-Pa)
Where;
Cf = Flow coefficient of valve (set at 0.5)
A = Area of open manhole or area of manhole lift
Pt = Absolute pressure inside the tank (inH2O)
Pa = Absolute pressure outside of the tank (inH2O)
My questions which nobody has been able to answer (hopefully until now) are as per below.
1) Is the absolute pressure the pressure at which the manhole cover begins to lift or is it the design pressure of the tank or the maximum design pressure as set by Appendix F of API 650?
2) The orifice are of the manhole. Are these units meant to be in "inches" or "feet"?
Thanks in advance.
Nfpa 30 Emergecny Vent
Started by Leinster, Mar 15 2011 11:32 PM
Posted 15 March 2011 - 11:32 PM
Posted 19 March 2011 - 03:14 PM
Orifice area is expressed in square inches, as per NFPA 30.
As per my understanding of the paragraph (a), Pt should be the opening pressure i.e. the pressure at which the flow area is fully open.
Posted 07 June 2011 - 09:05 AM
Many thanks for the response Zauberberg.
How would you calculate the pressure at which the manhole is fully open? The opening pressure is simple to calculate however I am not really sure where to go once the manhole has begun to lift.
Drain And Vent Destination LpgStarted by Guest_Priolo_* , 14 Feb 2026 |
Atmospheric Tank Vent SizingStarted by Guest_kmic_* , 30 Sep 2025 |
Free Vent For Api 650 Tank - Bug Screen / Bird Screen RequirementStarted by Guest_Cabbarbeybaba_* , 03 Jul 2025 |
