I have started sizing a new 3-p separator to separator gas/condensate/water.
The preliminary sizing of the separator using simple geometry rules has given me a vessel of 1.6 m (ID) x 4.8 m (T/T). When I started the firm sizing of the separator, I had the following results:
Dimensions: 1.8m x 5m (T/T)
L/D assumed :3
L/D calculated: 2.8
The thing is: Whenever I increase the surge and holdup times of the vessel, the vessel dimensions decreases. Although, it makes since using the question, I can't get it.
The excel sheet is attached.
I have used the sizing procedure called "Successfully specify Three-phase separators" by Wayne Monnery and William Svrcek (Univ of Calgary).
Could you please help me to find out whether this procedure is right or wrong?
Thank you,
Sherif
