Fired Heaters
Started by devesh sharma, Apr 05 2011 08:36 AM
Posted 05 April 2011 - 08:36 AM
The pressure inside firebox is lower than outside; why does flue gas exit without compression?
Posted 05 April 2011 - 09:23 AM
Devesh:
How did the pressure inside the firebox go lower than outside in the first place? Surely an induced draft fan would be there? If the fan is there, that is your compression step!!!
Posted 05 April 2011 - 10:13 AM
the pressure inside the fire box can be lower (slight vac) even without ID or FD fans. its buoyancy law, light gases go up and if you have a properly sized stack your hot gases being lighter than cold gases outside the fire box will create this slight vacuum as they go up the stack.
cheers,
SM
cheers,
SM
Posted 05 April 2011 - 10:29 AM
When observed on a basis of absolute pressure units, you'll see that flue gases always flow from the area of high pressure to the area of low pressure. The key concept is to account for static head of atmospheric air at different elevation levels, observed from a reference line (stack damper or outlet, for example).
See attached file for further clarification.
Posted 05 April 2011 - 10:53 AM
Apoligies for the half answer posted above. I was going to write about natural draft and density difference (as has been written already), but my typing was interrupted and the half answer got posted
Posted 09 April 2011 - 04:32 AM
Dear Devesh,
I am attaching a diagram. Hope i might be able to help you understand.
Posted 09 April 2011 - 05:32 AM
Actually,it is better to say lower pressure inside is created due to flue gas outgoing!
Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
High Stack Temperature In Ccr HeatersStarted by Guest_viba0124_* , 30 Nov 2024 |
Troubleshooting Temperature Overshooting In Convection HeatersStarted by Guest_Alaa55_* , 27 Oct 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
Electric HeatersStarted by Guest_panoska_* , 24 Sep 2022 |
