I am sizing a vent for fire relief for an 80,000 gallon atmospheric storage tank. More specifically,the tank is existing and I am checking the size of an existing vent. The content of the tank is edible oil with between 100 and 1000 ppm water. The edible oil has a B.P. of 1550 oF, so with no water in the system, no vaporization would occur before the failure temperature of the metal is reached. This, I believe, was the original assumption for specifying the tank vent ( 4 inch diameter conservation vent), although the design calculations are not available.
The introduction of water into the calculation (soluble in the oil at these concentrations) results in a lower bubble point (approximately 680oF) and a fire venting rate that is twice that which the existing vent can handle. Because I am checking an existing installation, I am interested in getting input regarding the treatment of trace impurities in storage tank contents. Is there a lower limit ( partial pressure, perhaps) below which they do not typically get addressed?
Thank you in advance for any assistance.
Storage Tank Vent Sizing For Fire
Started by mlai, May 03 2011 06:20 PM
Posted 03 May 2011 - 06:20 PM
Posted 03 May 2011 - 11:28 PM
mlai,
Have a look at the following links about various safety considerations for Atmospheric Storage tanks:
http://www.wermac.or...nks_safety.html
http://www.process-s...tanks-fire.html
![]() Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
![]() Free Vent For Api 650 Tank - Bug Screen / Bird Screen RequirementStarted by Guest_Cabbarbeybaba_* , 03 Jul 2025 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
