Difference Between Antisurge & Spill Back
#1 mannan
mannan
  • 16 posts
Posted 05 July 2005 - 09:11 AM
Dear friends,
What is the difference between Antisurge and spill back? somewhere mentionened antisurge and somewhere spill back ,, I am not clear about this.
thanks in advance.
#2 mbeychok
mbeychok
  • 364 posts
Posted 07 July 2005 - 12:16 PM
Mannon:
If you are talking about centrifugal or axial flow compressors, a recycle line from the compressor discharge back to the compressor suction is provided to prevent surging of the compressor at low flow rates. Such a recycle line if often called an antisurge line or a spillback line. In that context, the two terms have the same meaning.
  • guestGuests
  • 0 posts
Posted 27 July 2005 - 05:12 PM
Dear friend,
Centrifugal FEED pumps are often associated with a spill back line with a control valve. In case the receiving unit stop taking feed suddenly, the pump discharge is routed through the spill back to suction, thus keeping a minimum flow of the pump always. It is also called the minimum circulation line.
  • guestGuests
  • 0 posts
Posted 16 August 2005 - 06:21 AM
hi i just wanted to know if this concept applies on the pumps of reflux drum
