Having considered the interesting previous posts, following views on the diagrams (presented in "Furnace efficiency.xls", post No 1) could be useful as a try for interpretation (comments welcomed). Points are assumed to represent "experiments" in steady conditions for a few hours (not e.g. daily averages); while points of Jan-11 (being on y axis) have been omitted.
1. In Jan - Feb - Mar 11 measurements, fuel is about 50% fuel oil (FO) and 50% fuel gas (FG), w/w, while total fuel burning (kg/h) seems more or less same (~1650 kg/h). Flue gas temperature (understood as exit temperature) decreases, so furnace load increases and efficiency had to increase. This has not been realized on Feb 11 due to higher excess air (3.6% O2 in flue gases).
Note: What does "flue gas temperature" represent? It seems high for flue gas exit to atmosphere, it might concern exit from radiant section or just upstream e.g. a steam heating coil at end of convection section. Efficiency in the diagrams is understood to refer to part of the furnace, from which flue gases come out with reported temperature. 2. On May 11 total fuel burning (kg/h) has practically remained as before (very light increase), but weight ratio FG/FO increased. Efficiency jumped to 71%, as also indicated by the decrease of "flue gas temperature". This was due to lower excess air and some increase of furnace load (approaching normal capacity), since FG has reportedlly higher LHV than FO (on weight basis, post No 3).
Note: NHV (per kg) of FO / FG could make things a bit clearer.3. On Jun 11 FG burning was same as May 11, but FO burning was sensibly reduced further. Decrease in efficiency is due to reduction in furnace load (going far from normal), also to excess air increase.
Higher efficiency means less fuel energy (that is LHV) at constant furnace load. As mentioned in posts, best efficiency is for normal capacity and conditions (where performance guarantees are based on).Modern burners can burn even heavy FO using only 5% excess air, higher than required excess air would reduce efficiency (actually seen this in steam boiler proposals).
Note: Substituting all FO with FG does not necessarily mean increase of efficiency, since flame will get much less luminous (Nelson, Petroleum Refinery Engineering, Chapter on Tubestill Heaters).
Edited by kkala, 16 November 2012 - 10:13 AM.
