Hello!
Thanks for welcoming me here.
I have a personal question that is imprtant to me...about pool safety and environmental impact of chemicals used in pools.
Which has the most impact on the environment? polyhexamethylene biguanide and peroxide OR chlorine systems?
Thank you for your help.
Pool Chemicals
Started by Guest_caretaker_*, Jul 24 2005 08:11 AM
#1 Guest_caretaker_*
Posted 24 July 2005 - 08:11 AM
Posted 24 July 2005 - 11:16 PM
QUOTE (caretaker @ Jul 24 2005, 08:11 AM)
Hello!
#3 Guest_caretaker_*
Posted 27 July 2005 - 12:36 PM
I see that nilesh_chem wanted to post something....but clicked on the wrong button maybe?
All I have learned so far is that mercury is involved in the production of chlorine. And that chlorine ages the human skin and body. Hydrogen Perxoide is an oxygen producer however I have no idea what the manafacturing of it or PHMB involves...and the environmental impact of them.
any thoughts?
any thoughts?
#4 Guest_Guest_*
Posted 06 September 2005 - 10:54 AM
I think the worst thing about forums is the misguided information that can be found in them by individuals who have heard something and want to pass that information on. I work at a Cl2 production facility. Yes, mercury is SOMETIMES used in Cl2 production, but most companies who still use this outdated process are moving to other methods of production. Chlorine is made using electrolytic cells or membrane cells for the most part now. Even in the processes that still use mercury, it is not leached into the products. It is only used for the electrolysis. To answer the question, I know nothing about the other process, but I know that Cl2 production is not as harmful as you have been lead to believe.
By the way, it is not pure chlorine that is put into pool chemicals. It is calcium hypochlorite. If you want to know, research that chemical.
Pool Water Ionization Using Copper ElectrodesStarted by Guest_fragant-western_* , 29 Aug 2023 |
Api 521 Pool Fire Heat Input EquationsStarted by Guest_Vegeta_* , 24 Jan 2023 |
Answered
Price Of ChemicalsStarted by Guest_Noran Shedid_* , 17 Mar 2020 |
Chemicals Melting PlasticsStarted by Guest_Qasem215_* , 01 Oct 2020 |
Looking For Open Source Reference Containing Ld50 Values Of Chemicals.Started by Guest_ChinmoyBasak_* , 19 Jul 2020 |
