Can any help to learn about Sand Separator. how it works? and how to size it?
Thank you
SS
Sand Separator
Started by process101, Aug 26 2011 04:13 PM
Posted 26 August 2011 - 04:13 PM
Posted 27 August 2011 - 12:35 AM
SS,
A sand separator is nothing but a soild-liquid hydrocyclone where the sand is removed with some quantity of the liquid from the bottom of the cyclone and the sand-free liquid is removed from the top. There have been several topics related to hydrocylones on the forum. Just use the search feature of the forum by typing in the keyword as "Hydrocyclone". You will get many posts on the subject.
Posted 01 September 2011 - 10:27 AM
Of course, if you want to grade the sand, the settling tank has a water flow rising through the tank and overflowing a wier.
The sand particles will tend to sink at different rates according to their size.
By adjusting the flow rate you can control the size of particle carried over the wier.
Traditionally a bubble gauge would be used to sense the slurry quality in the "teeter" zone. You can use a tuning fork density meter for the same control function.
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
![]() Discharge Scrubber And Suction SeparatorStarted by Guest_Falah_* , 21 Jul 2024 |
![]() Flash Drum And SeparatorStarted by Guest_Abdellahi_* , 28 May 2024 |
