A Problem In Flarenet
#1 montazer
montazer
  • 11 posts
Posted 10 September 2011 - 01:42 AM
dear all
I have a problem in simulation of header line to a flare tip. the problem is that whatever the inlet pressure of a control valve is, the upstream pressure of the line next to it, doesnot change. i dont know if its correct or no. if any body knows anything about this problem, plz help me. thanks
Edited by montazer, 10 September 2011 - 01:43 AM.
#2 Lowflo
Lowflo
  • 180 posts
Posted 11 September 2011 - 02:08 PM
Your problem statement is not clear.
#3 montazer
montazer
  • 11 posts
Posted 11 September 2011 - 11:51 PM
I mean that if i set the inlet pressure of control valve on 100 bar or 1.073 bar the control valve outlet pressure does not change dramatically(1.022 to 1.042 bar)!!
what is my mistake?
#4 chemperson
chemperson
  • 18 posts
Posted 21 September 2011 - 02:47 AM
Dear Mon,
Flarenet calculates only backpressure at outlet of CV and also the philosphy behind its calculation is from flare tip to CV outlet .
Hope this will serve your purpose
#5 montazer
montazer
  • 11 posts
Posted 26 September 2011 - 03:33 AM
dear all friends
I need a useful and several case study contained booklet in flarenet software.(no aspen flarenet userguide or refference manual.they are not useful to me.)
can anybody help me?
#6 Petroman
Petroman
  • 4 posts
Posted 06 October 2011 - 03:15 PM
dear all friends
I believe the Flarenet Reference Manual is pretty detailed and easy to follow. You may consider joining in one of the Webinars that Aspentech arranges once in a while. Then you can learn a lot about Flarenet right on your work PC. You have to be registered with Aspentech online to get an invite of the web seminar though. On the other hand you can try searching for a training session from Aspentech. Nobody will publish proprietary stuff for you in an online forum as you have requested.
