I am currently undertaking a basic chemical engineering thermodynamics class. As part of a certain project I need to specify the length, diameter and no. of tubes and how they should be arranged for a condenser that utilizes water. Tubes are limited to a length of 8 m and the fluid velocity must not exceed 6 m/s. Can anybody tell me how solving this works or at least point me to resources i can use.
Condenser Design For A Geothermal Plant
Started by BennyT, Sep 22 2011 10:39 AM
Posted 22 September 2011 - 10:39 AM
Posted 25 September 2011 - 01:24 AM
Did you try the search or Download buttons on this forum ?
I've attached an xcelsheet issued by Art Montemayor .
This should help.
This should help.
Posted 25 September 2011 - 08:33 AM
This almost single-handedly solved my problem with the interrelated variables, thanks.
Posted 26 September 2011 - 03:47 AM
what are the formula being used in designing condenser ?
we are need to design surface condenser in our project.
pls help us asap...
pls help us asap...
Posted 26 September 2011 - 07:39 AM
Let you get a copy of Kern : Process heat transfer or
Coulson and Rodchardson's Vol 6 : chemical engineering design;
or use this free resource :
http://www.wlv.com/p...ok/databook.pdf
This should support your query .
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
