I want to solve this problem of a drying operation.
How do I plot a drying rate curve?
the file below contains the details:
drying rate.xlsx 11.91KB
48 downloads
Posted 02 October 2011 - 03:55 AM
Posted 04 October 2011 - 09:16 AM
Attached "drying.xls" can hopefully help, since it is not easy to explain procedure in words.
Posted 04 October 2011 - 01:34 PM
well this is how I did it.
sir Q numericals.xlsx 15.59KB 34 downloads
But I am confused with weather the moisture content be on dry basis or on wet basis for the graphical representation as well as for the calculation of the drying time?
please elaborate.
Regards.
please elaborate.
Regards.
Edited by chemiboy11, 04 October 2011 - 01:35 PM.
Posted 05 October 2011 - 06:27 AM
Work on the "sir Q numericals.xlsx" seems satisfactory to my understanding, some comments are included in the attached "dryingR0.xls".
You should use dry weight basis on all treatments / graphs of data. In this way you avoid confusion too. Good info on the subject can be found in "Solids drying fundamentals", Chapter of "Psychrometry, Evaporative Cooling, and Solids Drying" in Perry's "Chemical Enginner's handbook". It is Chapter 12 in the 7th edition (1999).
Ammonia Evaporation Rate InquiryStarted by Guest_aslungaard_* , 30 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
How To Calculate Cooling Rate Of CrystallizerStarted by Guest_snehchem_* , 04 Jan 2024 |
Answered
Multiple Psvs Relief RateStarted by Guest_fmalik_* , 02 Dec 2023 |
Rate Law For Heterogeneous CatalysisStarted by Guest_DREAMINGNREC_* , 16 Aug 2023 |
