So for the equation yi * P = xi * γi* Pisat , yi and P are known.
My question is whether or not my plan to solve for the liquid phase and Temp make sense.
1. I plan on guessing T, plugging that into the Antoine Equation to get Pisat.
2. With the Pisat I will calculate xi with the assumption of Raoult's law.
3. Knowing xi, I can use our three parameter margules equation to solve for γi.
4. Using γi I will recalculate xi using the top equation
5. Then again calculate γi.
6. Go through steps 4 and 5 until little difference in iterations is observed.
7. With γi, xi, and Pisat (and yi already known), I will calculate P.
8. Continue changing the temperature till calculated P equals real P (1 atm).
There are two issues with this. We are asked to use the SRK EOS to see how well the equation of state describes the vapor phase. Since yi is given, I am not sure how to do this. If I find correct temperatures using the above plan, I could then solve the SRK, but I would have three roots. How do I know which root is the volume of my vapor? And even if I find that volume, how do I check the calculated volume against the given molar vapor compositions?
The second issue is of the three parameter margules. We are told Ai = sum(xj * Aij) from j = 1 to 3, which means I will need to know a value for Aii ( A11, A22, A33). We are only supplied with Aij(A12, A13, A21, A23, etc.) values. How do I calculate Aii?
Edited by absolute0, 23 October 2011 - 09:46 PM.
