Equipment In Hf Service
Started by sgoel, Jul 11 2003 11:09 PM
Posted 11 July 2003 - 11:09 PM
We are facing a problem of frequent jamming of a pump on HF service. On opening casing wear ring is found to be tapered. Both, pump and wear ring are made up of monel.
Can anybody suggest the cause and remedial actions to be taken?
thanking you in anticipation
regards
Posted 05 October 2007 - 03:00 PM
QUOTE (sgoel @ Jul 11 2003, 11:09 PM) <{POST_SNAPBACK}>
regards
Check what type of Monel you are using.
There are different types of Monel as there are different types of Stainless Steel.
Monel alloys are not suitable for low concentration of liquid HF, try Teflon pump if you are using low temperature (no more than 120 0C)
Bringing Back Sponge Absorber To Service EvaluationStarted by Guest_mje03_* , 30 Oct 2023 |
How Does Aspen Edr Calculate U Service For S&t Exchangers?Started by Guest_daraj_* , 02 Oct 2023 |
Equipment Spec SheetsStarted by Guest_Ken Bicknell_* , 07 Jun 2023 |
Heat Losses Of EquipmentStarted by Guest_panagiotis_* , 20 Oct 2022 |
