I need a case either in the chemical or petrochemical industry for SCC. I need references to articles/reports that can be accessed for FREE as most of the ones I landed on are either not free or have limited access.
thank you in advance.
Case Of Stress Corrosion Cracking In The Industry. References Needed.
Started by Guest_eco-friendly_*, Nov 08 2011 03:52 AM
#1 Guest_eco-friendly_*
Posted 08 November 2011 - 03:52 AM
Posted 08 November 2011 - 05:45 AM
Did you try Google ?
I've attached a link to support your query
http://www.imoa.info..._2d_Edition.pdf
Hope this helps
Hope this helps
Psv Fire Case Relief Load CalculationStarted by Guest_mahmooddalvi09_* , 21 Feb 2024 |
Guidance Needed For Sizing A Knockout Drum With Multiple Psv DischargeStarted by Guest_fmalik_* , 04 Dec 2023 |
Hx Psv Sizing: Tube Side Fire Case With Shell Side Being Steam.Started by Guest_tamueng_* , 07 Nov 2023 |
Type Of Scrubber Needed To Remove Hcl Venturi Or Packed Bed ?Started by Guest_pckr9386_* , 13 Oct 2023 |
Kettle Reboiler Tube Rupture CaseStarted by Guest_aniljani_* , 03 Aug 2018 |
