Hi all, I was wondering if anyone could advise.
I have designed a vertical thermosyphon reboiler and am currently calculating the shell thickness and additional lengths for nozzles etc.
I have chosen a AEL TEMA design.
I am wondering what are typical lengths for the A and L head types?
(from my understanding the exchanger part, which i have designed as shell and tube, is contained in the "E" section and the process inlets and outlets are contained in the A and L sections - is this correct??? I have obtained my tube lengths, hence my E length but am confused as what to do about lengths for A and L)
Also, slight stab in the dark here, my final reboiler design is rather long. Could anyone advise, how I would design two vertical thermosyphons in parallel?
Any input would be much appriciated! Thankyou!
Tema Stationary Heads: What Size? & Parallel Thermosyphon Advice
Started by Guest_quantum_*, Nov 13 2011 09:09 AM
heat exchanger thermosyphon reboiler
#1 Guest_quantum_*
Posted 13 November 2011 - 09:09 AM
Posted 13 November 2011 - 11:51 AM
Quantum,
Welcome to ChE forums. To answer your questions and to provide some additional information:
1. There are no "typical" lengths of the channel head and the rear head of an exchanger. The size depends on tube-side flowrate and pressure (thus defining the nozzle size), tube layout, and type of the head. Probably some other factors are involved, from Mechanical point of view.
2. Parallel reboilers are designed with symmetrical inlet and outlet piping, and with identical exchangers. Also, depending on how they are fed from the column, the feed arrangement has to be symmetrical as well. Before going for parallel reboiler arrangement, be sure that you really need 2 reboilers instead of 1.
Have a look at this file compiled by Art Montemayor, available for free download:
http://www.cheresour...-heat-transfer/
More information about Shell&Tube heat exchanger is available in "Process Heat Transfer" classic book, written by D.Q.Kern.
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , Yesterday, 02:02 AM |
Maximum Nozzle Size In The Api 650 TankStarted by Guest_rudiawan_* , 18 Oct 2023 |
Advice WantedStarted by Guest_PaulColbert_* , 03 Sep 2023 |
Advice For A Future Chemical EngineerStarted by Guest_JamesMaxwell_* , 26 Aug 2023 |
Two Parallel Jt Valves For GasStarted by Guest_Mohamed_Mamdouh_* , 19 Jun 2023 |
