Pipe Flow 3D Solve The Cooling Water Network
#1 deltaChe
deltaChe
  • 153 posts
Posted 23 November 2011 - 09:18 AM
Dear Sir/Madam
I have created a simpe Excel tool (hardy cross method) to calcuate the water distribution through a network.
But, our new project is required to develop a cooling water network with seven coolers(supply and return pressure, delta P / elevation of each cooler and pipe rack) has been given, and boost pump may be requried to
be used if the pressue head of the end user is not sufficient
It's quite complicated, and seems can't be used this simple excel progam to work out.
I tried to use pipe flow 3D progamto give it a try and I wonder any pro got any pipe flow 3D tutorail or better sugeestion for this case.
Thank you very much.
#2 GS81Process
GS81Process
  • 96 posts
Posted 23 November 2011 - 03:29 PM
I have in the past used a program called KORF to solve a cooling water hydraulic network problem.
#3 breizh
  • 6,898 posts
Posted 23 November 2011 - 08:54 PM
Let you download from INTERNET PSIM (pump system improvement tool) , it should support your query .
