Hi everyone,
My problem is very straightforward. I want to export the feed stage number of a distillation column from HYSYS to excel, but I don't know what object I should select when I'm coding the macro. Any suggestions?
Thank you very much!
Excel Macro Object For Column Feed Stage
Started by fydphm, Dec 16 2011 11:16 PM
hysy export to excel
Posted 16 December 2011 - 11:16 PM
Posted 01 January 2012 - 03:33 AM
My knowledge in this is area is pretty poor but getting most of the variables is possible.
When I search for ‘feedstage’ using object browser in HYSYS library it shows, class as _TraySection and member as FeedStages but TraySection class is somehow hidden (I don’t know what that means in VB). If you can use this, task should be very straight forward.
Few variables are actually not exposed in OLE but most of the variables are exposed in script manager. To combine power of two methods, record a simple script using script manager which will give you monikers and call these monikers using backdoor entry in VB. Again I don’t know exactly how this is done (OLE part, scripting is pretty straight forward) so can’t write code for you. Probably below link may help you
http://www.eng-tips.....cfm?qid=169881
Ethylene Glycol Purification ColumnStarted by Guest_sg21255_* , 19 May 2026 |
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
Packaging And Gas Velocity In Packed ColumnStarted by Guest_ChemEng_CristianoB_* , 25 Jun 2025 |
