4
Column Sizing
10 replies to this topic
#1 guoyinyanliner
guoyinyanliner
  • 85 posts
Posted 21 September 2026 - 06:57 AM
​"When using HYSYS to calculate column internals for either a structured or random packed column, the calculated pressure drop is extremely low and falls below the lower limit. In this scenario, does it significantly impact the separation efficiency? Additionally, what is the appropriate percentage of column diameter to select when operating at the minimum vapor/liquid load
  • 7,064 posts
Posted 21 September 2026 - 06:46 PM
To your question the answer is yes, contact between liquid and Gas is key for the separation.
#3 guoyinyanliner
guoyinyanliner
  • 85 posts
Posted 21 September 2026 - 07:54 PM
Thank you, but it doesn't seem to be what I need
#4 Pilesar
  • 1,698 posts
Posted 22 September 2026 - 12:30 AM
From your initial post it seems you are trying to determine the percentage of distillation column cross-sectional area to fill with structured or random packing. I suspect your questions are really different from that. Perhaps you might give additional background and information so more people can understand what you are doing and where you want input from this forum. Then those who choose to respond may be less likely to waste their time trying to help you in ways you do not need.
#5 Bitan729
Bitan729
  • 36 posts
Posted 26 September 2026 - 03:08 AM
Sir, which book it is?  (pdf.gif  EQUIPMENT_DESIGN_LECTURE_25 mass transfer equipment 3.pdf )
#6 breizh
  • 7,064 posts
Posted 26 September 2026 - 04:03 AM
Hi Bitan,
To answer your question,
Chemical engineering design
6th edition
by Ray Sinnot and Gavin Towler
#7 guoyinyanliner
guoyinyanliner
  • 85 posts
Posted 28 September 2026 - 02:29 AM
What I want to know is: when I select the normal operating load, the column diameter is calculated based on an 80% load capacity; however, when the column operates at a low load—such as only 10% or even lower—how does this affect the separation performance?
#8 breizh
  • 7,064 posts
Posted 28 September 2026 - 03:56 AM
Where did you get that the diameter is based on 80% load capacity?
You cannot operate a distillation column at a low capacity like 10%.
You must stop and restart when the feed stock is sufficient enough to operate the column. This means you need a buffer tank (feed tank).
Stop and go will create off spec products till the equipment is running steady state.
By the way, is it a continuous process or a batch process?
Distillation Column Minimum Wetting Rate Calculation Guide – Industrial Monitor Direct
Diapositiva 1
Microsoft Word - ENGINEERING-DESIGN-GUIDELINES-distillation-column-packing-hudraulics-Rev1.2
0005benn
EDIT:
It may be an English language issue, the 80% is related to flood velocity: details in the link underneath
Distillation Column - 360° Interactive 3D VR Distillation Laboratory
For low gas flowrate, check for weeping condition and how to mitigate it.
FACTORS AFFECTING DISTILLATION COLUMN OPERATION
Good luck.
#9 latexman
  • 1,934 posts
Posted 28 September 2026 - 08:45 AM
Turndown Ratio = Maximum Capacity (Flow/Vapor Rate) / Minimum Capacity (Flow/Vapor Rate).
Random packing has a higher turndown ratio of 5:1 to 10:1, while structured packing typically has a lower turndown ratio of 3:1 to 5:1.
The overall column turndown is often limited by the design of the liquid distributor at the top of the bed. Standard orifice distributors may limit turndown to 2:1 or 3:1, whereas specialized designs can achieve higher ranges.
#10 guoyinyanliner
guoyinyanliner
  • 85 posts
Posted 29 September 2026 - 02:34 AM
Diapositiva 1
0005benn
EDIT:
Good luck.
It is an absorption column, not a distillation column
#11 breizh
  • 7,064 posts
Posted 29 September 2026 - 03:43 AM
All the things related to flooded column is also valid to find the tower diameter of an absorption tower.
See link below:
Packed Tower Absorber Design: Packing Material, Bed Height, Internals
I did my part. Good luck.
