Instrument/utility Air Buffer Drum Sizing
#1 Afshin445
Afshin445
  • 194 posts
Posted 27 December 2011 - 08:56 PM
I try to size an instrument/ utilty air buffer drum. I know how I can find the totla volume of vessel, but I don't know how I can fix the height and diameter of vessel.
Is it any rule of thumb or criteria availabel for such a sizing?
Edited by Afshin, 27 December 2011 - 08:58 PM.
  • 6,733 posts
Posted 27 December 2011 - 09:13 PM
http://www.cheresour.../exprules.shtml
Let you try this resource
#3 Afshin445
Afshin445
  • 194 posts
Posted 27 December 2011 - 09:57 PM
Dear Breizh,
I went through the article but I didn't find any criteria for Air buffer drum sizing.
Afshin
#4 breizh
  • 6,733 posts
Posted 27 December 2011 - 10:27 PM
L/D #3 !
Additional resource
http://www.engineeri...vers-d_846.html
Edited by breizh, 27 December 2011 - 10:59 PM.
#5 Afshin445
Afshin445
  • 194 posts
Posted 27 December 2011 - 11:00 PM
Dear Breizh,
Thank you for your fast reply. Could you please advise me what's base for that figure.Is it based on minimum vessel capital cost or something else?
Afshin
G. Gas velocities in gas/liquid separators, velocity = k (liquid density/(vapor density-1))^0.5,
Edited by Afshin, 27 December 2011 - 11:01 PM.
#6 breizh
  • 6,733 posts
Posted 27 December 2011 - 11:13 PM
Probably cost !
#7 Afshin445
Afshin445
  • 194 posts
Posted 28 December 2011 - 02:35 AM
Dear Breizh,
For my case I changed L/D ratio from 1 to 7 and estimated the weight for each L/D ratio.With higher L/D ratio vessel need lower thickness compare to lower L/D ratio.For my case L/D ratio of 5 give me lower vessel weight, but the vessel hight will be around 7.8 m. Can I select this dimension?There is no any limitation on height or dimeter?
