Htri
#1 sacc
sacc
  • 9 posts
Posted 03 January 2012 - 09:26 AM
hi to everybody & experts
1. is Rating Datasheet needed to be transfer in to Design Mode for complete the calculations or how we can friz the calculation by using Rating or Design?
2. when we got data /spec. from client how we come to know that it is for Rating or Design or Simulation
what exactly points to be considered for this 3 options
#2 DB Shah
DB Shah
  • 156 posts
Posted 03 January 2012 - 10:11 PM
Dear sacc,
Design, Rating and Simulation are three modes of cal in HTRI (or in any other hex software)
Design Mode
You input the process conditions required and leave the geometry of the exchanger open (with some basic input plugged in like - fluid allocation in shell/tube side, TEMA type, max tube length, max allowable dp, fouling etc) Simulator will give you various options of geometry in a tabulated form.
Rating Mode
You plug in detail geometry of the exchanger, plug in required process parameters and in/out temp required. Simulator will predict performance of the exchanger- % over design, calculated pressure drop, vibration levels.
Simulation mode
It is same as rating mode, except you do not specify outlet temperatures of the hot & cold fluids. By iterative calculation simulator will arrive at a condition where all the available area is utilized, and under this condition it will predict the outlet temperatures of the hot & cold fluids.
Divyang
