Mixing Two Streams At Different Pressure Through Gas Ejector
No replies to this topic
#1 ChemEng01
ChemEng01
  • 84 posts
Posted 17 January 2012 - 11:41 PM
Does anybody know the method to determine the outlet pressure and temperature of a flare gas ejector.
I have a high pressure stream and a low pressure stream entering the ejector and I need to determine intermediate pressure and temperature of gas produced. I know inlet P T and Q of the HP and LP streams.
Flare gas ejectors are designed to recover low pressure gas and re-use it instead of flaring.
If the calculations for this are too complex I have acess to HYSYS if anyone knows how to do it.
The outlet flow will be a simple mass balance
Am I right to assume the temperature could be estimated assuming no heat loss and doing a mass balance on the enthalpies?
The question is. What is the intermediate pressure??
Any help will be greatly appreciated.
cheers.
Edited by JRudd, 22 January 2012 - 09:21 PM.
