I am requested to check the possibility to product diesel from crude oil on offshore platform to feed gas turbine. I have made some rechearch but don't found reference for similar application.
We look after a mini refinery with simplified process system focused only to the extraction of diesel , all the by product will be recycled to the crude oil system.
Will apreciate if any one can inform about minimum dimension for such unit because we have a layout contraint. we expect a unit to produce between 1000 to 2000 baril/day of diesel.
Many thanks in advance
Local Diesel Offshore Extraction From Crude Oil
Started by mondher, Jan 20 2012 06:04 AM
mini refinery
Posted 20 January 2012 - 06:04 AM
Posted 20 January 2012 - 05:52 PM
The problem would be that you would need to distill a significant volume of crude to get that much diesel, depending on the crude assay. The equipment may not be "huge", but you will need to heat the oil to high temperatures (fired heater), and condense the naphtha. You have seawater, but metallurgy could be expensive for that.
Posted 21 January 2012 - 12:53 PM
thanks for your answer,
Can you help guiving an example of similar application, photo, diagram , ....
Is this solution well known and used on offshore platforms ?
Posted 24 January 2012 - 10:42 PM
I do not know of any installations of such facilities on offshore platforms.
See here for info on land based units:
http://images.pennne...p_9929jpch2.jpg
http://images.pennne...p_9813jgo03.jpg
http://en.wikipedia....iki/Shell_Haven
http://www.cosasco.c...tion_towers.jpg
Prv Vs Extraction Condensing TurbineStarted by Guest_mj311_* , 13 Nov 2024 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
![]() Green Diesel StorageStarted by Guest_Lucianaa_* , 16 Feb 2024 |
