Hi all,
I have a burner for drying product that use to run off of propane but now runs on CNG (compressed natural gas). The flow meter on the feed line gives a reading of 2923 SCFH. From this reading I used a conversion of 1035 BTU/cf, or 1.035 therms/ccf (given by supplier) to get a rate of 3,025,305 BTU/h.
The problem is when I look back at past propane usage, the BTU's don't match.
Typically, we would use 642 gal/h propane, which ralates to 58,743,000 BTU/h (using 91,500 BTU/gal propane), but this means we're only using 5% of the BTU's we use to use!
I suspect the problem may lie in the SCFM units. Any ideas are much appreciated.
Thanks,
Mike
Cng Meter In Scfh - Need Btu's
Started by Subject_Name_Here, Feb 07 2012 10:06 AM
natural gas meters energy content propane scfh
Low Pressure Air Flows Thru Orifice Meter Plate QuestionStarted by Guest_sfhh_* , 24 Feb 2023 |
Orifice Flow Meter Lead Line BlockageStarted by Guest_Pronab_* , 12 Feb 2021 |
Magnetic Flow Meter Operational IssueStarted by Guest_JKM_* , 18 Sep 2019 |
Flow MeterStarted by Guest_rikakose_* , 20 Aug 2019 |
Coriolis Flow Meter Pressure DropStarted by Guest_shahidulislam48_* , 08 Jun 2017 |
