Hello everyone,
Does anyone have experience in dealing with pyrophoric build in MVR filters going from inerted to non-inerted vessel loading? I'm working on a project that installs filters upstream of detonation arrestors in the client's MVR system. A question was raised if these filters could experience pyrophoric build resulting in a fire/explosion going from inerted to non-inerted loading. The initial suggestion was to clean the filters prior to going to non-inerted loading, however, we chose fiberglass filters that aren't designed to be cleaned. Before we re-spec these filters, I'd like to know if this is a viable scenario? The MVR is used for full range finished gasoline, gasoline blending components (naphtha, light/heavy reformate, alkylate) and benzene. Any help would be greatly appreciated.
Thanks,
EC
Pyrophoric Build In Mvr Filters
Started by NOEC, Feb 08 2012 09:30 AM
No replies to this topic
Posted 08 February 2012 - 09:30 AM
Back Pressure In FiltersStarted by Guest_panoska_* , 22 Jan 2024 |
Teg FiltersStarted by Guest_Whisper1231123_* , 03 Jul 2022 |
Hello, I Build A Rectify Process Simulation Softwear For OtsStarted by Guest_simulationstudent_* , 08 Jan 2021 |
Strategy To Build A Hysys SimulationStarted by Guest_titim_* , 19 Mar 2018 |
Heat Exchanger Build Material! Hysys Economic Analyzer!Started by Guest_stratovona266_* , 15 Mar 2018 |
