Dear all,
I need to know as per NFPA22, what will be minimum storage time (hrs) will be for sizing the fire water sump volume.
Fire Water Sump Storage Time
Started by Narnia, Feb 16 2012 01:43 AM
Posted 16 February 2012 - 01:43 AM
Posted 16 February 2012 - 01:49 AM
- I've in mind 4 hours min.
Posted 16 February 2012 - 02:21 AM
Any reference of it w.r.t NFPA code
Is it according to point No 7.2.9.1 mentioned in NFPA 22??
Posted 16 February 2012 - 02:38 AM
It's based on the last three chemical plants I've been in charge where Fire fighting system were designed based on NFPA XX and audited by Insurance.
What you are refering is the resplenishment of the tank after an event .Your tank must be "always" full of water in case .
Here you need to talk to the fire fighting bureau where the plant is or will be located to ensure the compliance with regulations.
Edited by breizh, 16 February 2012 - 02:55 AM.
Posted 16 February 2012 - 03:59 AM
No i just want to know what NFPA recommends that sump volume to be calculated on basis of how much fire duration?
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
