I came to know that the vacuum tower in our oil refinery has got one stainless steel cladding in the flash zone.I would like to know why a cladding is provided in the flash zone of the column and not in the other zones of the column.Any suitable answers?
Stainless Steel Cladding In Vacuum Distillation Tower Flash Zone
Started by Guest_vijay_*, Oct 07 2005 11:13 AM
Guest_vijay_*
Posted 07 October 2005 - 11:13 AM
Posted 12 October 2005 - 09:21 AM
Normally vacuum towers are clad from the bottom up to HVGO return. Normal claddings material used is 304L. The reason why this columns are clad is because of sulphidic and naphtenic corrosion. If the column is going to process high naphtenic crude, instead of SS304L is even better to use SS317L.
Luis Marques
Luis Marques
Guest_vijay_*
Posted 13 October 2005 - 02:37 AM
Thanks Luis Marques,
Iam happy to note the contents.but can u further elborate the chemistry of corrosion in the bottom area.Why is that naphthenica corrosion is not in other parts.Also sulphide corrsoion is possible?Iam not sure about this.If so what is the chemistry?
Vijay
Vijay
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
