I'm currently trying to simulate a ethanol water distillation column on hysys. I started with a short cut distillation column, but i keep getting the same error " A minimum reflux ratio below zero has been calculated for yoru distillation". the compositions I'm using are, 0.15 water in distillate and 0.0091 ethanol in the bottoms. Can anyone provide any help?
Cheers
Posted 24 February 2012 - 06:24 AM
Posted 24 February 2012 - 06:48 AM
Consider this resource it may help to understand the issue
http://www.chemsof.com/vle/vle.htm
then Data ; Y=f(x)
then Data ; Y=f(x)
Edited by breizh, 24 February 2012 - 07:11 AM.
Posted 24 February 2012 - 08:22 AM
Thanks for the link, it showed me how many stages I needed. I used this and went back to hysys, this time with the actual distillation column and it is giving me the error that it doesnt converge?
Posted 24 February 2012 - 12:38 PM
there could be many reasons why your simulator cannot find a suitable solution even for a binary mixture, for example a set of unfeasible specifications or wrong models for VLE or enthalpy etc. you may start with a model as Wilson or NRTL for VLE, check that the proper BIPs are available, differently you may use a predictive model as UNIFAC.
For the column do not specify a component's fractions or a purity, you may instead specifiy a reflux and a flow (bottom or top), you may change the flows if the solver is unable to find a solution (since you have two components to separate).
Once you have found a solution you may modify reflux, flows etc. in order to reach the desired separation.
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , Yesterday, 03:06 AM |
Importing Component Stream Data From Hysys To Excel Using VbaStarted by Guest_TimL_* , 17 Aug 2018 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
