Dear all,
Does anyone have any knowledge of pretreating an oily water mix that currently exists as an emulsion. It is thought that the cause of the emulsion is a wetting agent used during asbestos removal. Also present are solvents (in low concentrations), Tritiated water, and possibly some Co60.
Any help is appreciated!
Cheers,
Nick
Oily Water Separation- Emulsion Pretreatment
Started by Nick (6 Engineering Ltd), Nov 02 2005 11:48 AM
Posted 02 November 2005 - 11:48 AM
Posted 02 November 2005 - 10:44 PM
Sounds like a good application for Ultrafiltration. Depending on the final water quality desired... you could possiby use an RO/NF membrane combination to remove more than just the oil... potentiall replacing other downstream treatment. There is a huge variety of membranes out there.. the various suppliers will be able to suggest appropriate membrane choices and likely separation efficiencies.
Hope this helps!
Nat.
Hope this helps!
Nat.
Posted 04 November 2005 - 02:49 PM
You could try heating a test sample to see if there is a reasonable break-out temperature for the emusion.
Then the easiest way to separate it is though heating and gravity separation.
Pem Water ElectrolysisStarted by Guest_tomr91_* , 29 Jul 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
