Flarenet File
#1 annu_739
annu_739
Posted 21 March 2012 - 08:34 AM
Is there any way of opening the flarenet file of version 7.2 with 6.5?
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 24 March 2012 - 01:01 PM
annu,
Probably if the .fnw file can be converted to .xml file you may be able to open it in the older version. You will have to check this out.
Generally newer version files cannot be opened in the older version. However, older version files can definitely be opened in newer version.
Ankur
#3 dattatray kolte
dattatray kolte
  • 18 posts
Posted 24 September 2012 - 10:01 AM
Yes.
You have to use export wiz.
As said by ankur. U need to do some trial & error as i had also faced same problem.
