Dear All,,
For designing a shell and tube condenser to condense acetone vapors i have to use "-20 brine" as coolant in shell side that compose of 60% water and 40% methanol.
Now i should know Cp of coolant. can I do the math like
.6 x .99 + .4 x .605 = .836 kcal/kg C
where .99 and .605 are Cp of water & methanol respectively.
Another problem is that process is under vacuum and pump suction capacity is 300 m3/hr. we aim at condensing 20 kg of acetone over 06 hrs of drying with 60% recovered in 1st 02 hrs. what should be my assumption for flow rate of acetone vapors?
thanx in advance
Saleda
Brine Speific Heat Calculation
Started by saleda, May 05 2012 05:07 AM
