Hi everyone!
I'm courrently working on a treatment unit for some sour gas coming from an oil field. The first part of the plant, the compression unit, works at ambient T and low P, and at a certain point the material choosen for compressors and lines change from carbon steel to stainless steel, but I cannot understand why.
Pressure changes from 3 to 11.5 barg, wile T changes from 44.7°C to 126.9°C. There is no condensation of water, even if there is a 0.56%, and there's an high concentration of sour gas (H2S=4.2%, CO2=7.05%).
What's the effect of pressur in this kind of "hot" corrosion?
Thanks!
Alex
Posted 16 May 2012 - 09:16 AM
Posted 16 May 2012 - 10:51 AM
Alex,
You need to find out the partial pressure of H2S in the system where the material specification changes from CS to SS. Most likely it has been evaluated that the partial pressure of H2S in the system after the material specification break is equal to or greater than 0.3 kPa (0.05 psi), In such a case, according to NACE MR-0175 you need to provide Sulphide Stress Cracking (SSC) resistant steels. Some information can be found therough the web link related to NACE MR-0175 provided below:
http://pipelineandga...nment?page=show
Check in your engineering documentation and most likely you will find the explanation provided above for switching from carbons steel to stainless steel at a certain point.
CO2 in your gas stream is also high and can form corrosive carbonic acid in presence of trace quantities of water.
Hope this helps.
Hope this helps.
Posted 17 May 2012 - 02:26 AM
Dear Ankur
Thank you for your reply.
According to NACE MR-0175 there is no reson for change CS to SS only for SCC.
In other words, once the selected material is CS NACE, there is no condition (high pressure or high temperature) for replace it with SS NACE.
Do you agree?
Do you agree?
Posted 17 May 2012 - 01:18 PM
Alex,
If your Carbon Steel itself is NACE MR-0175 compliant for preventing SSC, then yes I agree that you don't need to change to stainless steel.
Posted 18 May 2012 - 02:03 AM
Dear Ankur,
thank you again for your kind reply.
I would ask you one more thing related to corrosion, which is: once stainless steel is chosen for high H2S concentrations in pipes, is there any necessity for a PWHT?
Thank you again!
Thank you again!
Posted 18 May 2012 - 03:01 AM
Alex,
AS per NACE MR-0175, Austenitic Stainless Steels (SS316, SS304,SS309, SS310, SS209) do not require PWHT. Amongst Corrosion Resistant Alloys (CRAs) only martensitic stainless steels require PWHT (e.g. SS 410, SS 415, SS420, J91150, J91151, J91540, SS424).
Hope this helps.
Hope this helps.
Posted 18 May 2012 - 03:27 AM
Thank you very much Ankur!
Control Strategy For 2 Air Compressors In ParallelStarted by Guest_panoska_* , 31 Oct 2025 |
Constant Volume Vs Constant Mass Flow Of Centrifugal CompressorsStarted by Guest_panoska_* , 18 Nov 2024 |
Centrifugal Compressors (Actual Vs Polytropic Head)Started by Guest_panoska_* , 25 Oct 2024 |
Spillback In Centrifugal CompressorsStarted by Guest_Venkat @89_* , 14 Jun 2024 |
General Balance Of Energy On Compressors, QuestionStarted by Guest_MumtazDogan_* , 29 Apr 2024 |
