Referring to API2000 i found that inbreathing, outbreathing regarding thermal and fluid movement should all be taken in consider.
In my case, there are tanks with normal venting (no PRV is used) how can I esitmate the optimal size of this vent (i.e) how can I show by calculations(e.g) that 4" diameter vent is enough for the purpose of breathing.
knowing that tanks are monomer storage tanks (styrene, Butyl acrylate, ...)
I appreciate your help,,
Edited by nes13ta, 28 May 2012 - 04:06 AM.
