Hi everybody,
I want to calculate radiation isopleths for a propylene flare with following design basis:
propylene max flow: 21200 kg/hr
propylene normal flow: 12000 kg/hr
temp: 55 DegC
LHV: 20115 btu/lb
flare ht: 48 m
air velocity avg: 5 m/s
this topic is very new for me so please help me for this calculation.
How Do We Calculate Flare Radiation Isopleths
Started by chandan1681, Jun 14 2012 05:26 AM
flare radiation
Posted 14 June 2012 - 05:26 AM
Posted 05 October 2012 - 03:42 AM
If you want to generate isopleth graph the only way that you can do is to use software
one software that I know can generate this is FlareSim by softbits consultant
you can goole it and try to gain more info
However if you just wanted to know the radiation on certain point, you can use calculation
that is provided in API STD 521
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
![]() Flare And Venting SystemStarted by Guest_miz19_* , 10 Jul 2024 |
Calculate Mabp,wabp,cabp And Meabp From Distillation Astm D86 ResultsStarted by Guest_barks123_* , 30 Apr 2024 |
